Mbstudio restart!
07 Feb 2020 00:17 #89564 by Medeiros
Mbstudio restart! was created by Medeiros
Hi
I notice that sometimes MB Studio shuts down and reconnects without having scheduled a software restart.
Is this normal now?
07 Feb 2020 00:27 #89565 by MB RADIO
Replied by MB RADIO on topic Mbstudio restart!
It's possible this happens if the system resources goes down, the software restart to avoid a crash.
07 Feb 2020 00:33 - 07 Feb 2020 00:35 #89566 by Medeiros
Replied by Medeiros on topic Mbstudio restart!
This is happening about 2 to 3 days.
If it does not cut the audio, it always leaves the audio at the end.
Is there another solution?
Last edit: 07 Feb 2020 00:35 by Medeiros.
07 Feb 2020 00:38 #89567 by MB RADIO
Without restart the program will crash. It should be searched what is causing the low resources. Are you using OBS in the same computer? or VMix?
07 Feb 2020 00:41 #89568 by Medeiros
I'm using the same computer OBS.
07 Feb 2020 00:50 #89569 by MB RADIO
ok, if you want send a debug and i will look into it.
07 Feb 2020 00:52 #89570 by Medeiros
Tomorrow I send.
Thanks.
