MBMusicReport
28 Mar 2019 18:23 #87402 by Medeiros
MBMusicReport was created by Medeiros
Maurizio
For Portugal in MBMusicReport it would be possible to put the option Language, Gender, Gender2 and Gender3?
This already worked for the Portuguese Radio Law.
30 Mar 2019 19:41 #87445 by MB RADIO
Replied by MB RADIO on topic MBMusicReport
31 Mar 2019 20:06 #87448 by Medeiros
Replied by Medeiros on topic MBMusicReport
MB SOFT wrote: done www.mbradio.it/en/component/rsfiles/down...StudioInstall862.exe
:) :) Thank you very much. I'll try.
01 Apr 2019 10:32 #87453 by Medeiros
I installed version 8.62.2.0 but every time MBMusicReport opens this message.
01 Apr 2019 10:35 #87454 by MB RADIO
MB STUDIO Songs menu Save Archive
01 Apr 2019 18:00 #87458 by Medeiros
MB SOFT wrote: MB STUDIO Songs menu Save Archive
Thanks.
01 Apr 2019 21:47 - 01 Apr 2019 21:49 #87459 by Medeiros
I'm sorry, Maurizio.
I was thinking of using the genres of MBStudio to put this information into the Law and Portugal of Portuguese music.
However I had another idea that may be simpler and that does not interfere with the function of MBStudio.
It is possible to create within the "info" of the songs the options:
Nationality:
Expression:
And MBMusicReport has the option "Nationality", "Expression", "Code" (already exists in the info),
I need this information in MBMusicReport:
Time (already exists)
Duration (already exists)
Artist (already exists)
Music Name (already exists)
Nationality (create because it uses codes)
Expression (create)
Year (already exists)
Code (create)
Any questions I'm available.
Last edit: 01 Apr 2019 21:49 by Medeiros.
01 Apr 2019 21:55 #87460 by MB RADIO
you can use genre2 for Nationality and genre3 for Expression
for the "code" i can add to print that value in the MusicReport.
01 Apr 2019 22:08 - 01 Apr 2019 22:18 #87461 by Medeiros
MB SOFT wrote: you can use genre2 for Nationality and genre3 for Expression
Yes, my idea was that. I'm just afraid that this information might later interfere with MBStudio's programming functions. So be saying to put in "Info" of songs.
I'm talking about this:
What do you say?
Last edit: 01 Apr 2019 22:18 by Medeiros.
01 Apr 2019 22:28 - 01 Apr 2019 22:30 #87462 by MB RADIO
i think you can use genre2 and genre3 without problem to store nationality and expression.
however if you need extra fields for that you have to wait few weeks because for now i cannot modify the music database
Last edit: 01 Apr 2019 22:30 by MB RADIO.
02 Apr 2019 00:19 - 02 Apr 2019 07:20 #87463 by Medeiros
MB SOFT wrote: i think you can use genre2 and genre3 without problem to store nationality and expression.
If you think there's no problem with the genres, fine. OK. I am waiting for the update of MBMusicReport with the code and insertion date of the song, to be YYYY-MM-DD (example: 2019-03-12).
Last edit: 02 Apr 2019 07:20 by Medeiros.
02 Apr 2019 15:15 - 02 Apr 2019 15:29 #87467 by Medeiros
I think you have to use the capo "Comment" because "code" does not have to apply to multiple files.
Last edit: 02 Apr 2019 15:29 by Medeiros.
Time to create page: 0.102 seconds
