MB LIVE per Android
21 Jan 2019 16:58 - 22 Jan 2019 01:53 #86936 by Medeiros
Lavori in corso: MB LIVE Android was created by Medeiros
Will it be possible in the settings to have the option to enable/disable: "Keep the screen turned on"
This is so that your smartphone/tablet does not turn off the screen.
Last edit: 22 Jan 2019 01:53 by MB RADIO.
21 Jan 2019 17:00 #86937 by MB RADIO
Replied by MB RADIO on topic MB LIVE per Android
I don't know. I have to investigate and i don't know if the Android OS give me the permisison to do so.
21 Jan 2019 17:21 #86938 by MB RADIO
Replied by MB RADIO on topic MB LIVE ANDROID is available for download
22 Jan 2019 01:15 #86947 by Medeiros
Replied by Medeiros on topic MB LIVE per Android
Luci Android software has this option.
I think it's possible.
22 Jan 2019 01:53 #86948 by MB RADIO
I will add it in few days
22 Jan 2019 02:31 - 22 Jan 2019 02:32 #86949 by Medeiros
Thanks. :)
Last edit: 22 Jan 2019 02:32 by Medeiros.
24 Jan 2019 11:40 #86963 by MB RADIO
25 Jan 2019 13:45 - 25 Jan 2019 13:51 #86979 by Medeiros
MB SOFT wrote: added on version 1.62.0.5 play.google.com/store/apps/details?id=mbsoft.mblive&hl=en
Thank you Maurizio.
I do not want to bother.
Will it be possible to create multiple configuration profiles for MB LIVE on Windows and Android?
This is so that you may have to use two or more different ips / ports / passwords and not have to always load configuration data.
Last edit: 25 Jan 2019 13:51 by Medeiros.
25 Jan 2019 13:49 #86980 by MB RADIO
On windows you can already do it.
On androud i will add it
25 Jan 2019 13:56 #86981 by Medeiros
MB SOFT wrote: On windows you can already do it.
Ok...thanks.
