AAC streaming not working with latest version of Shoutcast (2.6)
  • GTHvidsten
01 Oct 2018 19:25 #86186 by GTHvidsten
I upgraded my Shoutcast server from 2.5 to 2.6, and now MBRecaster won't stream any AAC streams any more.
In the log file I get "source disconnected. Unable to sync to the stream. Please check the source is valid and in a supported format.". Even though it mentions "supported format", Shoutcast does support AAC streams.
When first installing my SC server I also had problems streaming AAC, but this was fixed by installing Quicktime. The only change now is the SC version.
How can I get AAC streaming working again?
01 Oct 2018 19:42 #86187 by MB RADIO
Are you meaning AAC or AAC+? Because MB RECASTER use AAC+ for rates up to 96kbits and AAC for rate from 128 and up.
Did you tried boths?
  • GTHvidsten
01 Oct 2018 19:44 #86188 by GTHvidsten
I only tried AAC (tried 128 and 256), and those didn't work. I didn't try AAC+ as the bitrate is a bit too low for my taste.
01 Oct 2018 19:46 #86189 by MB RADIO
i don't have a shoutcast server version 2.6 right now so maybe if you send me privately an account for your server i'll do some test here to check what's happening
01 Oct 2018 20:14 - 01 Oct 2018 20:14 #86190 by MB RADIO
I searched on google about a 2.6 version of Shotucast DNAS but not found. Are you sure it's 2.6 version? where did you downlaod it from?
Last edit: 01 Oct 2018 20:14 by MB RADIO.
  • GTHvidsten
01 Oct 2018 20:41 #86191 by GTHvidsten
I go to www.shoutcast.com/ then I log on in the upper right corner. When logged on I click my name at the top right, then choose "Manage your plan". From there I can "Download Shoutcast Server Software (2.6.0)".
I only have one available stream on my server, and I usually listen to it actively, so if I'm going to give you access we should set up some sort of private live chat so that I can make changes on the fly without having to go a day without music.
01 Oct 2018 20:50 #86192 by MB RADIO
i will try to download and install the server here on my system and i will let you know the results
01 Oct 2018 21:18 - 01 Oct 2018 21:19 #86193 by MB RADIO
i downloaded the server and in my opinion that version has a bug, do not support aac+ or aac streams, not only from MB RECASTER but also form any other encoder. So you have to wait that they fix the bug or reinstall the previous version of the server.
Last edit: 01 Oct 2018 21:19 by MB RADIO.
  • GTHvidsten
02 Oct 2018 16:43 #86196 by GTHvidsten
I created a support request with Shoutcast and their reply was that 2.6 is still in beta. Hopefully they'll fix this AAC issue in the final release.
After switching to 2.6 (and switching to MP3 streaming) my stream is much more stable than I reported here . Seeing as I changed two things I can't really tell if the micro stuttering comes from the server upgrade or the switch to MP3. Due to this stability increase I'll stick with the beta for now.
02 Oct 2018 19:02 #86199 by MB RADIO
latest version of shoutcast server do nto seems to be very stable, maybe you should think about a move to icecast. If you're stream from your own internet connection you can also test the stream aac with the internal server of MB RECASTER and see what happen
  • GTHvidsten
02 Oct 2018 21:56 #86201 by GTHvidsten
I looked into Icecast, but they don't officially support AAC. I've read that people have succeeded with AAC and Icecast, but the details are a bit lacking.
Have you been able to stream AAC to Icecast? If yes, is it a default installation of Icecast2, or do I need to do something special?
02 Oct 2018 22:08 - 02 Oct 2018 22:09 #86202 by MB RADIO
You can stream with icecast and aac or aac+.
Here my test stream icecast aac 128k
178.32.136.9:9033/stream
and the server version is here:
178.32.136.9:9033/server_version.xsl
Last edit: 02 Oct 2018 22:09 by MB RADIO.
