MB-Recaster, Embedded Album Art, How does client player extract image?
  • stevewa
17 Aug 2018 17:57 #85807 by stevewa
Hi Maurizio,
I have read that MB-Recaster can embed album art image into the stream.
I'm wondering how the player can extract that image from the stream to display it in the player.
I downloaded your MBPlayer, but anti-virus says it contains W32.Trojan.21fm, so I can't install it to try it.
Do you embed the album art jpg image in the stream as bytes, and then use those to reconstruct the image in the player?
Will images be displayed in other players for example "VLC Player (VIdeoLan)"
can 2 instances of mb-recaster be run on the same win pc? to send to 2 different shoutcast servers?
I am trying to do research if MB-Recaster will work as a Source encoid
17 Aug 2018 18:46 #85808 by MB RADIO
stevewa wrote: Hi Maurizio, I have read that MB-Recaster can embed album art image into the stream.
That's true, but due to a bug this is not actually working. It will be fixed in the upcoming version of MB RECASTER PRO. This feature will not be included in MB RECASTER FREE.
Currently only Winamp with the Album Art plugin display the instream artwork
Surely it's a false positive, what is your antivirus? Anyway MB PLAYER actually do not display instream artwork.
I use a standard feature of the Shoutcast2 protocol, i not invented anything :)
The logo picture and the now playing picture are available directly through the shoutcast 2 server, so if you want you can build your own radio player to display it.
Ex: my radio stream is: nr11.newradio.it:8056/stream and the logo picture is available here: while the now playing picture is here:
up to 10 concurrent sessions of MB RECASTER PRO can run in a single computer (each session require the purchase of an additional licence)
only 1 session of MB RECASTER FREE can run at the same time
  • stevewa
20 Aug 2018 18:28 #85813 by stevewa
thank you.
i'm using Immunet and Avast anti-virus, both report a virus, but with different virus names, so maybe it's just a false positive.
but now that you say mb player does not display the embedded image, i won't bother trying it.
I can't understand the license options. does it require a usb dongle to be installed on the computer? would each instance need it's own dongle?
20 Aug 2018 23:08 #85815 by MB RADIO
stevewa wrote: I can't understand the license options. does it require a usb dongle to be installed on the computer? would each instance need it's own dongle?
When you order the first license of MB RECASTER PRO an usb dongle is sent to your address. If you need multiple licenses (to run multiple MB RECASTER PRO on the same computer) additional licenses will be loaded into the usb dongle, so using 1 or 10 MB RECASTER PRO only need 1 USB dongle.
