MB Recaster Free - Run with Windows does not work
  • bootika
06 Mar 2018 15:06 #84760 by bootika
Hello,
I've tried two methods to make it start with Windows 10. None of them work:
1. Check the "Run with Windows" option. It turns green. In Task Manager / Startup, MBRecasterStartup appears as Enabled. If I reboot it doesn't start. If I go to settings afrer reboot "Run with Windows" is gray again
2. Put a shortcut to MB Recaster Free in Startup folder. It doesn't work
Do you have an idea where I go wrong?
06 Mar 2018 15:55 #84761 by MB RADIO
Please see here: www.mbradio.it/en/help/319-setup-always-...dio-as-administrator do the same with MBRecaster executable
  • bootika
06 Mar 2018 16:03 #84763 by bootika
It already was set to run as Administrator.. Forgot to mention :)
06 Mar 2018 18:35 - 06 Mar 2018 18:37 #84765 by MB RADIO
Do you also disabled UAC? winaero.com/blog/how-to-turn-off-and-disable-uac-in-windows-10/
Also be sure you excluded the MB RECASTER folder from the antivirus.
Last edit: 06 Mar 2018 18:37 by MB RADIO.
  • bootika
06 Mar 2018 19:51 - 06 Mar 2018 19:54 #84769 by bootika
UAC was disabled. The AV is Defender (Windows A/V) it never raised any issues.. :)
Last edit: 06 Mar 2018 19:54 by bootika.
06 Mar 2018 21:05 #84770 by MB RADIO
In your task manager there is a "clam antivirus", did you excluded the MB RECASTER folder from "Clam antivirus" configuration?
  • GTHvidsten
21 Jul 2018 13:45 #85677 by GTHvidsten
Replied by GTHvidsten on topic MB Recaster Free - Run with Windows does not work
I'm actually having the same issue. UAC is turned off, application is running as administrator, I do not have any anti virus running.
Still, I check the "Start with Windows" option, click "Close", quit the application, start the application, and "Start with Windows" is unchecked again.
  • bootika
23 Jul 2018 10:16 #85680 by bootika
Eventually I used a software named Startup Delayer (www.r2.com.au/page/products/show/startup-delayer/) . Now it loads MB Recaster just fine. Without this program it wouldn't work, thow..
One other issue is that after booting, MB Recaster doesn't find the capture card selection. It displays nothing in the dropdown, and the radio doesn't start, because of no audio input. I have to manually re-select it in order to start playing..
Does anybody know how to fix this?
23 Jul 2018 10:44 #85683 by MB RADIO
GTHvidsten wrote: I'm actually having the same issue. UAC is turned off, application is running as administrator, I do not have any anti virus running.
Yes, there is a bug, It will be fixed asap
  • GTHvidsten
23 Jul 2018 11:46 #85684 by GTHvidsten
Thanks for confirming. Now I don't have to scratch my head trying to figure out what's wrong with my setup :)
