Sending RDS to DEVA via internet
  • radio7
13 Jun 2017 15:53 #83026 by radio7
Sending RDS to DEVA via internet was created by radio7
Hello.
I need help with sending RDS data from MBStudio to DEVA DB6400 model on transmitter side over internet. If it is possible, how to send it to more transmitters?
Thanks.
13 Jun 2017 19:52 - 13 Jun 2017 19:53 #83028 by MB RADIO
Replied by MB RADIO on topic Sending RDS to DEVA via internet
I'm sorry but currently DEVA RDS are only supported by cable. I'm trying to find informations on how to transmit commands via TCP / UDP but no info about it on the DEVA website.
Last edit: 13 Jun 2017 19:53 by MB RADIO.
  • radio7
14 Jun 2017 14:13 #83031 by radio7
Replied by radio7 on topic Sending RDS to DEVA via internet
I found this: www.deva-audio-processor.com/dld.php?r=1251
I have tested DEVA's Virtual COM Port to Ethernet Tool settings from chapter 2. With Putty i can connect over serial port (virtual).
If i set this COM port in MBStudio i will get error message:
unable to connect to COM port in MBStudio:-(
Thanks.
14 Jun 2017 14:38 - 14 Jun 2017 15:02 #83032 by MB RADIO
This tool www.devabroadcast.com/dld.php?r=380 seems a solution. I don't have a DEVA RDS to test it. On WIndows 10 it seems it's not able to create the virtual COM port:
status: not created
could you please show me what is writing to you?
here also putty is failing:
Last edit: 14 Jun 2017 15:02 by MB RADIO.
  • radio7
14 Jun 2017 15:55 #83033 by radio7
OK. I have connected and... (see attachments)
We have windows7pro 32bit (on virtualbox). DEVA's Virtual COM Port to Ethernet Tool (i ran as admin).
14 Jun 2017 17:02 - 14 Jun 2017 17:02 #83034 by MB RADIO
ok maybe my problem is that i dont have a DEVA RDS encoder so the COM port is not created. I'll see if i can find one to test
Last edit: 14 Jun 2017 17:02 by MB RADIO.
