Recording Time settings in ReCaster
  • paul03034
08 Jun 2017 13:59 #82982 by paul03034
Recording Time settings in ReCaster was created by paul03034
Hello,
I have to bring this up again to point out the issue I have. Please consider a solution for more timing ability. It exists in other parts of your program on other features.
I have shows that are 59 minutes long, but they always get clipped or I air tone on-air.
Show starts at say 8:00:10 and ends at 8:59:10. The 10 second show delay is for 10 second ID
Start time is OK as it has 10 seconds of silence and that is removed with gap detection, so it it is cued to show start
End time is set for 8:58:00 which records for 59 minutes and then stops before shows end at 8:59:10 give or take a few seconds
When the show ends there is about 7-10 seconds of silence and then tone.
If I increase timer stop time to end at 8:59:00 I get 60 minutes record and the tone plays over the air.
I tried to shorten silence detection to less than 7 seconds, but that has caused the show to end anywhere there is 7 seconds of silence and since it has interviews that happens and show ends.
If I take show live from stream I have the ability to start stream at 8:00:10 and end at 8:59:10, but I don't want to air it at that time, so I am in a unsolvable situation. Record time is only settable to the minute. VOX function might work, but if they do interview and there is silence it could clip show. If VOX worked only during last minute of record then it would probably work, but seems having seconds would be better.
Thank you!
10 Jun 2017 00:43 - 10 Jun 2017 00:43 #82993 by MB RADIO
Replied by MB RADIO on topic Recording Time settings in ReCaster
paul03034 wrote: having seconds would be better.
Seconds are available in MB RECASTER PRO 4.2 www.mbradio.it/en/50-notizie/482-mb-recaster-4-2-pro-en
Last edit: 10 Jun 2017 00:43 by MB RADIO.
The following user(s) said Thank You: paul03034
  • paul03034
10 Jun 2017 02:38 #82994 by paul03034
Replied by paul03034 on topic Recording Time settings in ReCaster
Thank you very, very much!!!!!!!!
Great Fix !
Thank you again!
  • tomi-tong
12 Jun 2017 18:10 #83013 by tomi-tong
Replied by tomi-tong on topic Recording Time settings in ReCaster
I may have missed the info. But for what reason are not the seconds available on all functions of Mb Studio (the recorder in particular)? This could make programming easier.
13 Jun 2017 23:56 #83029 by MB RADIO
tomi-tong wrote: I may have missed the info. But for what reason are not the seconds available on all functions of Mb Studio (the recorder in particular)? This could make programming easier.
Only the scheduled recorder of MB STUDIO has no seconds but it will added this weekend. All other functions of MB STUDIO has seconds
