Cueing points in mp3
  • teutoradio
07 Jun 2017 14:39 #82967 by teutoradio
Cueing points in mp3 was created by teutoradio
When I label an mp3 with MB Studio, the information ( Start, Intro, Teaser In, Teaser out, Outro and stop will be saved in the IDTag of the mp3 or in an extra database of MB Studio?
07 Jun 2017 15:05 - 07 Jun 2017 15:08 #82968 by MB RADIO
Replied by MB RADIO on topic Cueing points in mp3
both in the file and in the database.
if you loose the database you'll retrieve the data from the audio file
if you loose the tag you still have the data in the database (use menu' Edit \ Write Tag to rewrite tag to one, some or all songs)
Last edit: 07 Jun 2017 15:08 by MB RADIO.
  • teutoradio
07 Jun 2017 15:52 #82969 by teutoradio
Replied by teutoradio on topic Cueing points in mp3
Where can i find the database ( name of the file ) ?
07 Jun 2017 16:19 #82970 by MB RADIO
MBSongs.dat
  • teutoradio
08 Jun 2017 22:30 #82985 by teutoradio
OK thanks!
What kind of database do you use? We have the problem, that we send sometimes some mp3 from the our MB Radio Automation to a partner radio station who use another system but the cant read the cueing points.
Is there a way to convert?
08 Jun 2017 22:38 #82986 by MB RADIO
Unfortunately there is not a standard to exchange cue point between different applications
