Encoder capture card change
  • paul03034
02 Jun 2017 00:35 #82932 by paul03034
Encoder capture card change was created by paul03034
Hello,
After the last update I lost my encoder capture card being used which was a special channel output. Now I see only MB Studio Mix, and EXT 1,2,3,4.
Before I was using my sound cards output 3 for streaming and output 4 for transmitter which are two different audio settings where one has transmitter pre-emphasis 75 us and the other no pre-emphasis and different audio processor settings for two distinct sounds outputs.
HELP!
Thank you!
02 Jun 2017 07:59 #82933 by MB RADIO
Replied by MB RADIO on topic Encoder capture card change
The following user(s) said Thank You: paul03034
Time to create page: 0.036 seconds
