MB Recaster record timing issue
  • paul03034
30 May 2017 15:10 - 30 May 2017 15:14 #82879 by paul03034
MB Recaster record timing issue was created by paul03034
Hello,
If I set a record for 8:00 it starts correctly, about a second before GOOD
I set a stop time of 8:59 and it continues recording to 8:59:59 which is 59 seconds past stop time Bad
It never seems to end at any stop time correctly.
I'm trying 9:30 - 9:58 to see if it goes past time and will update this post then.
Last edit: 30 May 2017 15:14 by paul03034.
30 May 2017 16:28 #82883 by MB RADIO
Replied by MB RADIO on topic MB Recaster record timing issue
the STOP time is inclusive, it means that the it will stop just at the end of minute 59. If you want to stop at 59:00 set the stop time at 58
  • paul03034
30 May 2017 16:59 - 30 May 2017 17:00 #82885 by paul03034
Replied by paul03034 on topic MB Recaster record timing issue
Just discovered that on :58 stop time.
Do you think you will ever be able to add the VOX function like in MB Spot to ReCaster Pro?
Thank You!
Last edit: 30 May 2017 17:00 by paul03034.
30 May 2017 17:19 - 30 May 2017 17:21 #82887 by MB RADIO
paul03034 wrote: Just discovered that on :58 stop time.
Yes i will add it in the near future
Last edit: 30 May 2017 17:21 by MB RADIO.
The following user(s) said Thank You: paul03034
  • paul03034
01 Jun 2017 00:25 #82919 by paul03034
Excellent and Thank You!
