Minilist and audio file
  • paul03034
15 May 2017 02:24 #82616 by paul03034
Minilist and audio file was created by paul03034
Hello,
I noticed that when I create a minilist the one thing with an audio file is even after changing audio file from standard mix to no mix it always reverts back to standard mix after saving. Some audio files in a minilist I might want a standard mix and others no mix and I can never save it like it does in regular playlists.
Suggestion of what I am doing wrong or is this a bug?
Thank you!
15 May 2017 02:40 #82617 by MB RADIO
Replied by MB RADIO on topic Minilist and audio file
I was unable to reproduce the problem here, i set "No Mix" to 2 files in a minilist and the property is still there after saving or even when minilist is on air
  • paul03034
15 May 2017 02:43 - 15 May 2017 02:55 #82620 by paul03034
Replied by paul03034 on topic Minilist and audio file
This only applies to minilist
I go and it is standard mix
[attachment:1]minilist 1.jpg[/attachment
I change to no mix and apply
I look at properties and it says standard mix
Last edit: 15 May 2017 02:55 by paul03034.
  • paul03034
15 May 2017 13:45 #82629 by paul03034
Here is the minilist that was set to no mix in the playlist.
I do not see anything saying no mix where it is inserted from minilist.
Playlist is fine and stores settings.
15 May 2017 17:11 #82631 by MB RADIO
fixed on version 8.59.1.1
The following user(s) said Thank You: paul03034
Time to create page: 0.069 seconds
