Wave files being generated using text to speech
  • paul03034
04 May 2017 00:17 #82478 by paul03034
Hello,
I noticed in the MB Studio Directory that when I use a SAPI5 text to speech voice it generates a wave file for the text file that is played out as speech in MB Studio. Where is this controlled to stop it from doing this. I must have checked something that started that issue.
Thank you!
04 May 2017 00:54 #82479 by MB RADIO
You cannot stop it. MB STUDIO need to create the speech file for playing it. But don't worry it is not going to create a new file undefinitely. It will overwrite the same file for the same voice so it's not going to fill up your hard drive
  • paul03034
06 May 2017 00:16 #82508 by paul03034
Replied by paul03034 on topic Wave files being generated using text to speech
I just check and it is writing file after file and I have attached picture of folder full. I just counted almost 200 since yesterday evening.
Thank you!
06 May 2017 12:07 #82512 by MB RADIO
yes you're right ...something gone wrong on that version. Please update to 8.59.0.7 version and this should be fixed.
The following user(s) said Thank You: paul03034
Time to create page: 0.036 seconds
