Music of next hour
  • teutoradio
28 Apr 2017 21:49 #82403 by teutoradio
Music of next hour was created by teutoradio
Hi!
One question. Is it possible to play the refrain of songs that will be heard in the next hour in the playlist ?
29 Apr 2017 00:36 - 29 Apr 2017 00:37 #82406 by MB RADIO
Replied by MB RADIO on topic Music of next hour
Yes, it's possible. Use the Event REFRAIN.
Each event TEASER will play the Teaser (Refrain) of one of the following songs.
See this playlist as exemple where i play 9 refrain of the following 9 songs:
Last edit: 29 Apr 2017 00:37 by MB RADIO.
  • teutoradio
29 Apr 2017 00:48 #82407 by teutoradio
Replied by teutoradio on topic Music of next hour
but this is for the same hour.
I like to program for example:
at the end of one hour e.g. playlist 7:00 at 7:55 in the next hour ( 8:00 ) you will hear after the news this song ( refrain ) and this song ( refrain )
and when the next playlist of the next hour ( 8:00 ) will be start the songs will be heard.
Hope you understand
29 Apr 2017 01:10 - 29 Apr 2017 01:11 #82408 by MB RADIO
Unfortunately you can play the refrain of the currently loaded playlist, not of the future playlist, because MB STUDIO don't know what songs will play until the playlist is loaded.
I don't think this is a big problem: you can load your playlist a little early let's say at minute :59 and create a break in MB SPOT at :59 that will play the refrain just before the news break at :00. this is just an idea but many stations do like that
So esemple:
12:59 Playlist 13
Last edit: 29 Apr 2017 01:11 by MB RADIO.
  • teutoradio
30 Apr 2017 09:44 #82432 by teutoradio
Dear Maurizio!
I try to do this, but after install the latest version 8.59.02 in the event <i can't find the "refrain" option anymore. Can you check this?
30 Apr 2017 15:42 #82433 by MB RADIO
In English it's called "Teaser"
  • paul03034
21 Apr 2018 17:08 - 21 Apr 2018 18:59 #85029 by paul03034
Replied by paul03034 on topic Music of next hour
I suppose there is not a way to have the refrain/teaser random choice of how many you wish to tease?
Example:
In using your method/example of programming teasers above let's say there are 15 songs in a playlist and I wish to tease 5 of the 15 songs it will always tease the first 5 songs as to doing a random tease where it randomly picks 5 songs of the 15 songs to tease.
Or is there a way to get it not to do each song in a row, where it skips maybe the first two songs and does 3, 5, 8, etc.? Basically you pick a pick order of which ones to tease 3, 5, 8, 10, 15?
I can dream?
Next is there is a checkbox and time in setup for teasers and then the event with a teaser duration. The teaser duration in event has no effect on the length as it is overridden by the setting time. If I choose to uncheck allow teaser box in the setup I actually got the event time to work once and after that it skips all refrain/teasers in list. It would be nice to control length of at least first one as I was trying to use it as a background as Voice over is done on first teaser and I needed longer tease play than the others to do a VO over.
Thank you!
Last edit: 21 Apr 2018 18:59 by paul03034. Reason: additional info discovered
