Song reports for terestrial to ASCAP, BMI, SESAC
  • paul03034
21 Dec 2016 02:38 #81634 by paul03034
Hi,
How does one get any required reports to submit the air dates and times of songs to the royalty agencies in a format that they require. I only see print a report which would require manually typing in the reports (As I see It). Don't see any CSV or Microsoft Excel export functions to generate needed reports.
Thank you!
22 Dec 2016 20:29 #81642 by MB RADIO
You can export your song database in CSV using menu' Print in the song window. In Italy we export all the songs played in the previuos year with the hits count, i don't know how you need to export data in your country.
  • paul03034
23 Dec 2016 02:51 #81644 by paul03034
Replied by paul03034 on topic Song reports for terestrial to ASCAP, BMI, SESAC
I missed the fact there are log folders in the MBStudio program directory that almost meets my needs for reports (Or maybe does already), but I do not see anywhere to customize output. Am I missing that or is it hard coded? I am waiting for answer from BMI is format meets their needs.
I sent them copies of the logs to see if they are acceptable.
We have to submit monthly report or timeframe they request that shows in specific format which I do not know the layout or if pipe delimited:
Date/day/24 hour period that has, time, title, artist.
I think the others are the same and I will contact them this Friday.
Thank you!
