Play and next.
07 Dec 2014 19:20 #75934 by radiop
Play and next. was created by radiop
Good afternoon,
I wonder how to put the keyboard space bar to do or play next in MBSTUDIO?
Thank you.
09 Dec 2014 12:07 #75944 by MB RADIO
Replied by MB RADIO on topic Re:Play and next.
there the F buttons F1=PLAY F2=PLAY ALL  F3=AUTOPLAY F4=AUTOMATIC F5=NEXT etc etc
In the case you want to use the space bar first click the desired button (to put the fosuc on it) and then hit spacebar everytime you need. The spacebar send the click to the button that has the focus
10 Dec 2014 11:24 #75948 by radiop
Replied by radiop on topic Re:Play and next.
Thank you! :)
10 Dec 2014 15:32 #75951 by alvin
Replied by alvin on topic Re:Play and next.
Potresti spiegarmi la procedura per associare il tasto alla barra spaziatrice?
11 Dec 2014 00:47 #75957 by MB RADIO
Quando clicchi con il mouse su un pulsante (ad esempio NEXT) questo rimane leggermente evidenziato, ovvero ottiene il fuoco. A questo punto se clicchi la barra spazio equivale a fare click sinistro su di esso. E' anche possibile spostare il focus sui vari pulsanti premendo il tasto TAB.
11 Dec 2014 07:52 #75959 by alvin
Lo provo, grazie
12 Dec 2014 11:36 - 29 Dec 2014 13:56 #75966 by radiop
I understood, but there is no way to put the spacebar to next ultimately as with F5. Eg change of F5 for the spacebar without having to click on it. Thank you.
Last edit: 29 Dec 2014 13:56 by radiop.
