Modem GSM (MB Studio 8.50)
23 Nov 2011 02:48 - 23 Nov 2011 02:52 #61085 by Medeiros
Modem GSM (MB Studio 8.50) was created by Medeiros
Migliore supporto per modem GSM di varie marche (MB Studio 8.50)
Marche??
Marche Portugallo ( www.tmn.pt/portal/site/tmn/menuitem.7dbf...CM1000005401650aRCRD )
Last edit: 23 Nov 2011 02:52 by .
30 Aug 2012 20:15 #65526 by Medeiros
Replied by Medeiros on topic Re: Modem GSM (MB Studio 8.50)
Which card (modem) that I use for the service sms MB Studio 8.50?
It is possible to use the brand Huawei? What is the model?
04 Sep 2012 23:33 - 04 Sep 2012 23:43 #65567 by MB RADIO
Replied by MB RADIO on topic Re: Modem GSM (MB Studio 8.50)
Yes you can use the Huawei modem, this USB version should work.
www.huaweidevice.com/worldwide/productFe...008&treeId=582&tab=0
Last edit: 04 Sep 2012 23:43 by .
05 Sep 2012 21:49 - 06 Sep 2012 11:28 #65586 by Medeiros
Grazie Maurizio
Testato un Huawei 156g  e lavora.  :) :)
Sono con questo problema.
Esempio con errore:
Messaggio inviato: Rádio Sines
Ho ricevuto lo MB Studio: 004006F000760004060001000 ...
Esempio senza errori:
Messaggio inviato: Radio Sines
Ho ricevuto lo MB Studio: Radio Sines
Non accettato: é, ç, ã ...
Last edit: 06 Sep 2012 11:28 by .
05 Sep 2012 23:02 #65590 by MB RADIO
You should select menu Help/Send debug to MB SOFT because trough the forum i cannot see data to help.
06 Sep 2012 01:41 #65594 by Medeiros
I have sent!
It is information that were sent by mobile sms.
19 Sep 2012 21:08 #65747 by Medeiros
Any news about the problem?
