Vendo Antenne kathrein 770 776
07/07/2008 11:37 #30753 da
Vendo Antenne kathrein 770 776 è stato creato da
Le antenne sono praticamente nuove usate appena 7 mesi :'(  queste le caratteristiche:
Directional Antenna 87.5 – 108 MHz
770 776, 770 777
* 3 elements broadband Yagi antenna.
* Mounting to pipes.
* Vertically polarized.
* 4 dB gain.
Material: Hot-dip galvanized steel.
Mounting: To pipes of 60 – 125 mm Ø by means of 2 U-bolts, supplied.
Grounding: Via mounting parts.
Accessories: The antenna may be equipped with ice protection set Type No. 774 168 for use at sites with icy conditions (please order separately).
The max. wind speed with an ice layer of 3 cm is 130 km/h.
Le antenne sono con attacco flangia 7/16 e partitore con discesa Flangia 5/8 o 7/16
Per contatti info@radioflashfm.net
