MB Studio Instant Player bit issue using velleman
  • paul03034
02/06/2017 00:04 #82931 da paul03034
Hello,
I just found an issue after what worked failed to happen, so I had to find out why.
I have assigned bit 2 to instant player 1
Instant Players have send to N1 selected
This is so when Bit 2 is received Player 1 minilist is inserted into position 1
When the program MB Studio is restarted and a bit 2 is received from Velleman board nothing happens. The playlist continues as-is
If I click on the Instant Players button that opens the instant player window and click the close window it will now insert Instant Player 1's assigned minilist into playlist position 1 when a bit 2 is received.
It works every time once the instant Player window is opened and then closed.
This means you have to open and close the instant player window each time MB Studio is restarted and this creates a problem as we might not be around to do that if there is a crash or reboot, etc.....
Thank you for looking into this!
  • paul03034
05/06/2017 02:37 #82943 da paul03034
Risposta da paul03034 al topic MB Studio Instant Player bit issue using velleman
I guess the cure is to launch the Instant Player window and minimize it and leave it minimized so it will always work with programmed bits or keyboard keys assigned to it.
Seems to remember it was opened and minimized, so any Velleman bit commands will work in that situation when the computer is rebooted and MB Studio reopened.
Tempo creazione pagina: 0.040 secondi
