MBMusicReport
28 Mai 2019 23:54 - 29 Mai 2019 01:16 #87725 par Medeiros
Réponse de Medeiros sur le sujet MBMusicReport
All three numbers are required. But here in my not the "0" (custom 2) appears as you can see in the image I sent.
I sent a file by email.
02 Jui 2019 11:43 #87754 par Medeiros
Did you find the problem?
02 Jui 2019 12:03 - 02 Jui 2019 12:04 #87758 par MB RADIO
Réponse de MB RADIO sur le sujet MBMusicReport
no still not found. try to put the letter "O" instead of zero 0
02 Jui 2019 13:50 #87760 par Medeiros
MB SOFT écrit: no still not found. try to put the letter "O" instead of zero 0
But putting "o" instead of "0" does not accept ERC. For it is a letter rather than a number.
I do not remember because it does not copy the value entered in MB Studio.
04 Jui 2019 18:30 #87785 par Medeiros
But why not copy.
So I do not know and it does not serve us because I need to have the three figures.
Are you still going to see if you can fix it?
Thanks
04 Jui 2019 19:32 #87791 par MB RADIO
yes i will try to investigate again but here is writing all the characters, nothing is missing.
13 Jui 2019 23:17 - 13 Jui 2019 23:20 #87843 par MB RADIO
After further investigation i found no problems in MB STUDIO and MBMusicReport as the .csv file generated from MBMusicReport write 045
The problem is in Excel that automtically remove the leading zero from numbers.
So you can correct this in the cell configurations, choose Personal and set three 000
15 Jui 2019 19:43 #87849 par Medeiros
Yes, the problem is with Exel.
Know another program that opens the .csv file to see if it also happens the same.
What if Mbreport creates xlsv file? Also have this problem happened?
Thank you for everything and your work.
15 Jui 2019 20:13 - 15 Jui 2019 20:14 #87851 par MB RADIO
you can also use OpenOffice Calc but still you have to set the column Custom2 as Text when importing the .csv
22 Jui 2019 13:39 #87910 par Medeiros
I've solved the problem.
I was not able to get the changes saved in csv but writing to xlsx gets all the info.
Thank you Maurizio. :) :)
03 Aoû 2020 23:47 - 05 Aoû 2020 10:30 #90968 par Medeiros
It is possible in the next update to have in MBMusicReport the option "Music activation date" in this way DD-MM-YYYY.
Thanks.
02 Sep 2020 00:09 #91063 par Medeiros
Medeiros écrit: It is possible in the next update to have in MBMusicReport the option "Music activation date" in this way DD-MM-YYYY.
Thanks.
It's possible?
Temps de génération de la page : 0.081 secondes
