MBMusicReport
28 Mar 2019 18:23 #87402 par Medeiros
MBMusicReport a été créé par Medeiros
Maurizio
For Portugal in MBMusicReport it would be possible to put the option Language, Gender, Gender2 and Gender3?
This already worked for the Portuguese Radio Law.
30 Mar 2019 19:41 #87445 par MB RADIO
Réponse de MB RADIO sur le sujet MBMusicReport
31 Mar 2019 20:06 #87448 par Medeiros
Réponse de Medeiros sur le sujet MBMusicReport
MB SOFT écrit: done www.mbradio.it/en/component/rsfiles/down...StudioInstall862.exe
:) :) Thank you very much. I'll try.
01 Avr 2019 10:32 #87453 par Medeiros
I installed version 8.62.2.0 but every time MBMusicReport opens this message.
01 Avr 2019 10:35 #87454 par MB RADIO
MB STUDIO Songs menu Save Archive
01 Avr 2019 18:00 #87458 par Medeiros
MB SOFT écrit: MB STUDIO Songs menu Save Archive
Thanks.
01 Avr 2019 21:47 - 01 Avr 2019 21:49 #87459 par Medeiros
I'm sorry, Maurizio.
I was thinking of using the genres of MBStudio to put this information into the Law and Portugal of Portuguese music.
However I had another idea that may be simpler and that does not interfere with the function of MBStudio.
It is possible to create within the "info" of the songs the options:
Nationality:
Expression:
And MBMusicReport has the option "Nationality", "Expression", "Code" (already exists in the info),
I need this information in MBMusicReport:
Time (already exists)
Duration (already exists)
Artist (already exists)
Music Name (already exists)
Nationality (create because it uses codes)
Expression (create)
Year (already exists)
Code (create)
Any questions I'm available.
01 Avr 2019 21:55 #87460 par MB RADIO
you can use genre2 for Nationality and genre3 for Expression
for the "code" i can add to print that value in the MusicReport.
01 Avr 2019 22:08 - 01 Avr 2019 22:18 #87461 par Medeiros
MB SOFT écrit: you can use genre2 for Nationality and genre3 for Expression
Yes, my idea was that. I'm just afraid that this information might later interfere with MBStudio's programming functions. So be saying to put in "Info" of songs.
I'm talking about this:
What do you say?
01 Avr 2019 22:28 - 01 Avr 2019 22:30 #87462 par MB RADIO
i think you can use genre2 and genre3 without problem to store nationality and expression.
however if you need extra fields for that you have to wait few weeks because for now i cannot modify the music database
02 Avr 2019 00:19 - 02 Avr 2019 07:20 #87463 par Medeiros
MB SOFT écrit: i think you can use genre2 and genre3 without problem to store nationality and expression.
If you think there's no problem with the genres, fine. OK. I am waiting for the update of MBMusicReport with the code and insertion date of the song, to be YYYY-MM-DD (example: 2019-03-12).
02 Avr 2019 15:15 - 02 Avr 2019 15:29 #87467 par Medeiros
I think you have to use the capo "Comment" because "code" does not have to apply to multiple files.
Temps de génération de la page : 0.110 secondes
