MBMusicReport
02 Avr 2019 15:36 #87468 par MB RADIO
Réponse de MB RADIO sur le sujet MBMusicReport
It's impossible to have 2 songs with the same code, every song has a different code, what are the requirements of the law in your country? Could you explain better? do you have a document to see as example?
02 Avr 2019 18:01 - 02 Avr 2019 22:58 #87470 par Medeiros
Réponse de Medeiros sur le sujet MBMusicReport
Yes, I see.
Portugal it's a bit different.
Here the file has to be in XML
But the conversion from csv to xml I might be able to do (with the help of programmers, if MBMusicReport does not work with XML).
Exemple Portuguese:
<? xml version = "1.0" encoding = "ISO-8859-1"?>
<ERCRATIO>
<ALIAS>radioxxxxxxx</ALIAS>
<PLAYLIST>
<DATE>2019-02-01</DATE>
<SONG>
<TIME>00:06:44</TIME>
<DURATION>219</DURATION>
<ARTIST>SAM SMITH</ARTIST>
<MUSICTRACK>PRAY</MUSICTRACK>
<NATIONALITY>110</NATIONALITY>
<EXPRESSION>en-US</EXPRESSION>
<YEAR>2017-10-24</YEAR>
<PORTUGUESEM>0</PORTUGUESEM>
<ISRC/>
</SONG>
<SONG>
<TIME>00:10:25</TIME>
<DURATION>175</DURATION>
<ARTIST>MIGUEL GAMEIRO</ARTIST>
<MUSICTRACK>ALQUIMIA</MUSICTRACK>
<NATIONALITY>045</NATIONALITY>
<EXPRESSION>pt-PT</EXPRESSION>
<YEAR>2017-10-09</YEAR>
<PORTUGUESEM>1</PORTUGUESEM>
<ISRC/>
</SONG>
I need the fields:
TIME (time of issue)
DURATION (song length in seconds)
ARTIST (Artist Name)
MUSICTRACK (Name of Music)
NATIONALITY (Our Code - Example pt-PT; en-US; en-US ...)
EXPRESSION (Our Code - 000; 045; 010 ...)
YEAR (Date of insertion of song in MBStudio YYYY-MM-DD)
PORTUGUESEM (Put "1" if it is Portuguese and enter "0" if it is another language)
Attached to lists of codes for "Nationality", "Expression" and file XML.
I was trying to simplify using the genres and other MBStudio infos already.
02 Avr 2019 21:15 #87471 par MB RADIO
is this list an international standard?
as far as i know there is an ISO standard here: Country Code, ISO and Nationality gist.github.com/zspine/2365808 but it's different from yours.
anyway i have an idea to solve this customization for you and for any ohter that need custom values in the songs.
02 Avr 2019 21:42 - 02 Avr 2019 21:44 #87472 par Medeiros
MB SOFT écrit: is this list an international standard?
The List provided by the Regulatory Entity for Social Communication - ERC ( www.erc.pt/pt/fs/erc-in-english ) is not the one it refers to.
The XML that I sent for example is from a Portuguese automation software - AVA ( www.avaplayer.com ).
I'm waiting for news and thanks for everything.
03 Avr 2019 16:58 #87478 par Medeiros
Today I learned that it is also possible to send by template in MS Exel in addition to XML.
Here's the sample MS Exel template.
11 Avr 2019 17:08 #87529 par Medeiros
Any news?
11 Avr 2019 17:43 #87530 par MB RADIO
working
11 Avr 2019 19:53 #87531 par Medeiros
Thank you very much.
Will the custom Alias be able to repeat in multiple files at the same time? Not to make file to file.
Will the information appear in the list of MBStudio and MusicReport songs?
Many thanks for the hard work.
11 Avr 2019 19:55 - 11 Avr 2019 19:57 #87532 par MB RADIO
Medeiros écrit: Will the custom Alias be able to repeat in multiple files at the same time? Not to make file to file.
yes
yes
11 Avr 2019 20:54 #87533 par Medeiros
Thank you very much. This will be very good for the radios that use the software in Portugal.
I am waiting for the update of MbStudio with these functions.
Thanks.
28 Mai 2019 20:08 #87722 par Medeiros
There is an error when exporting to MBMusicReport it does not copy the entire information.
It appears only 45 and should be 045.
28 Mai 2019 22:32 - 28 Mai 2019 22:33 #87724 par MB RADIO
MBMusicReport don't cut the 0 but i think it's excel that it cut the "0". Look the original .csv file and you'll see the zero is there.
Temps de génération de la page : 0.115 secondes
