In this section you can create, modify or delete playlists and / or minilists.
There is no "Archive" section
The new files added to the playlist can be sent immediately to the server with a right click "Upload to server", however this is not necessary, as at the end of your work, you can click the SEND button which will upload to MB STUDIO PRO all new files ![]()
The moment you click SAVE, the new playlist is transmitted to MB STUDIO PRO and to all connected MB REMOTE.
