MB REMOTE presents on the home page the address book with the addresses to which we connected. This allows for easy reconnection by double clicking on the desired address.
To remove an address from the list, right click
To change an address click and then change the fields at the top and click "Connect"
The "Name" field is a nickname that you can give to your liking to easily recognize the link.
The addresses are saved in the address book only after the connection is successful.
