Those who use the video plugin to make radiovision have to face the problem of transmitting video even when they only have audio. Sometimes it is not possible to replace an audio file of a song with a video due to the poor audio quality of some video clips. In this case you can try to add a video clip to play simultaneously with the audio file by attempting to synchronize through the Intro point of the video file. Let's see the steps to follow to download a replacement video.
In the list of songs we open the pre-listening of the desired song:
Then select the "Download from YouTube" tab, set the selector to "Add Replacement Video", deactivate the "audio only" flag and finally click "Search"
The browser will show us the versions of the song available on Youtube and we click the desired one
under the video we click "Share"
copy the link from Youtube to MBStudio and select "Add replacement video"
Now click the "Download from YouTube" button and let MB STUDIO work.
At the end a replacement video file will be deposited in the static video folder and playback will start in pre-listening. To try a good synchronization between audio and video, you need to set the Intro point when the singer starts singing and you need to do it for both the audio and video files. once done, to see the result, click the song again from the song list:
and observe the synchronization between audio and video
if not satisfactory, change the sync point with the left or right arrow until the singer's lips move in sync with the audio
Note that sometimes it is impossible to get a good sync because the video clip is faster or slower or is of a differently edited version of the song.
