MB SPOT uses 2 print templates whose files are located inside the MBStudio\Sequences folder
LogItem.rtf (used to print the customer's past schedule - Report)
and
PrintItem.rtf (used to print the customer's future schedule)
To edit templates, in MB SPOT, use the Tools / Edit Template... menu and edit whatever you like (including the logo image), but do not remove the wildcards contained in the text (%schedule%, etc.).
If you remove the wildcards, dates and times will not be printed
If you accidentally ruin the files, you can re-download them from here: https://www.mbradio.it/service/Templates.zip (open the .zip file and put the 2 .rtf files inside the MBStudio\Sequences folder)
