The MB STUDIO playlist is represented by a list of objects of various types (Songs, Audio or Video Files, Events, Time Sequences, External Streams, etc etc). Each object is recognizable by its own icon on the left and by a background color.
With a left click on the icon on the left, the preview of the object is opened or a time sequence is unpacked.
With a left click on the number the object is immediately played. (modifiable in double click from the configuration)
With a right click on the number, all the objects up to the number clicked are played and then the automation stops.
With a double left click on a line of the object column you can insert a new object
With a right click on a line you can open other options
With a left click on the Remove column the object is deleted from the list (modifiable in double click from the configuration)
With a double left click on the Properties column you can modify the properties of the object. The property can also be accessed with a right click
With a left click you can change the width of each column
By holding down the left button on an object it is possible to move it within the list
It is also possible to drag objects from one list to another. Here is an example from the song list to the aired list. The same can be done from random files, breaks, external streams, History tab, Search tab and Folder tab
It is possible to customize the appearance of the list in Configuration \ Options \ More, choosing the grid color, hiding some columns and / or deciding a click or 2 clicks for some columns
You can customize the fonts in the list from Configuration \ Options \ Fonts
