Here's how to create your first dynamic PLAYLIST (for dynamic we means that the songs are automatically choosed by MBSTUDIO and not by you):
To create a new dynamic PLAYLIST click on Edit Playlist
In our first example we will build a rotation playlist that will play a random song, a random jingle, and so on.
It's required that you have loaded some songs in the library and at least one file in the random file library
Click the button New List
a) Double click on the first blank lineof the playlist and select the item Random File
leave the selection of Any and click Apply
b) Click the next position in the playlist and Insert Random Song
In the request usually leave all the choices on any and hit OK.
Repeat steps a) and b) how many times you want, but in general you can stop here.
Now set the Starting Time for this playlist
enable all the weekdays
enable the "Rotation non stop" option (so the playlist will cycle without stop)
enter a Title and a Comment (note that the title will be visible in the metadata of the stream) and click Save
The final result should be like this:
The playlist will be on air automatically at the scheduled time only if at that time MB STUDIO is in AUTOMATIC mode. To manually air a playlist at anytime click the button "Load Playlist" in the home screen of MB STUDIO.
