Channel name, Description, Genre, Home page
Enter the identification data of your station here, this data will help you to be visible in search engines and station lists.
Metadata filter
Here you can specify some wildcard characters that determine what will be displayed on the listeners' players.
If left blank, interpreter - song title or program title will be displayed
To customize the output some wildcard characters are used, here is a list of usable characters:
%timexx% - transmission time of object xx
%itemxx% - title of object xx
%yearxx% - year of object xx
%commentxx% - comment on the object xx
%albumxx% - album of object xx
%authorxx% - author of object xx
%labelxx% - object label xx
%codexx% - object code xx
%filexx% - file name of object xx
Examples:
to display only the title of the song on air: leave the box blank
to also display the song that will follow: %item0% next %item1%
to also view the year of the song on air: %item0% %year0%
to view free text plus song on air: you are listening to %item0% next %item1%
to also view the comment of the song on air: %item0% - %comment0%
Additional wildcards are explained here: WILDCARD WORDS TO CUSTOMIZE EXPORT
