- OnAir.txt - iif activated, MB STUDIO sends to the FTP server a small text file called OnAir.txt containing the title of the program or song currently on air. MB STUDIO sends the file automatically every time the object on air changes. On your website you can then exploit this file with some java, flash, php, asp applet or with any method that allows you to view the contents of a text file. The Text box must be empty or contain WILDCARD WORDS TO CUSTOMIZE EXPORT
- Playlist 1/2 - if activated, MB STUDIO sends to the server a file processed using the model you entered. On your website you can then exploit this file with some java, flash, php, asp applet or with any method that allows you to view the contents of the file. Template: here you can insert a template written in any language (text, php, java, asp, flash, etc etc) which must contain WILDCARD WORDS TO CUSTOMIZE EXPORT which MB STUDIO will automatically replace with the required contents.
An example of a text file that displays the next songs to be aired can be downloaded here: http://www.mbradio.it/download/Playlist.txt - Last songs played - Upcoming songs on air WEB EXPORT: PUBLISH UPCOMING OR BROADCASTED SONGS
- The FTP selector indicates on which FTP server the file is to be uploaded CONFIGURATION - WEB EXPORT - FTP
