Although the installer already perform the installation of the fonts used by MB STUDIO, sometimes on some computers, the installation may fail. In this case, MB and MB STUDIO SPOT show a message about a missing font.
To manually install the fonts, browse the MBStudio folder and then the Fonts subfolder, inside you will find 3 files, select them all (or one at a time) and then clicking the right button, select the menu '"Install"
