No acquisition card !
  • gandrew
20 Fév 2021 18:19 #92606 par gandrew
No acquisition card ! a été créé par gandrew
I used MB Recaster Free 4.6.5.6 or 5.0.0.8 on Windows 10 and I got the same problem. I'm back in 4.6.5.6.
I'm using the default card of the PC.The "Acquisition card" field is empty but the "sound card listening" field is filled.
Please see the screenshot
Fichier attaché :
Nom du fichier : Imagestudioradio.rtf
Taille du ficher :1,508 ko
20 Fév 2021 18:35 #92607 par MB RADIO
Réponse de MB RADIO sur le sujet No acquisition card !
Maybe you want to capture a "loopback"? if so you must enabled the loopback in the options and restart
  • gandrew
20 Fév 2021 18:56 #92608 par gandrew
Réponse de gandrew sur le sujet No acquisition card !
Thank you for your answer.
I enabled "loopback". I restarted MB Recaster and now I get "illegal device number".
I can select the card in "acquisition card" but I've a loopback. :(
20 Fév 2021 19:06 - 20 Fév 2021 19:06 #92609 par MB RADIO
Probably the input that you want to use is not enabled in windows. Show me the cards that you have in windows control panel audio
me i have this:
  • gandrew
20 Fév 2021 19:22 #92610 par gandrew
20 Fév 2021 19:29 #92611 par MB RADIO
You must look at "enregistrement" not to "lecture"
  • gandrew
20 Fév 2021 19:42 #92612 par gandrew
20 Fév 2021 19:48 #92613 par MB RADIO
ok as you can see no entry is active. To activate it, you need to connect an audio cable to the corresponding jack
  • gandrew
20 Fév 2021 19:51 #92614 par gandrew
I've a cable with 2 speakers, which works !
20 Fév 2021 19:55 #92615 par MB RADIO
yes but you must connect something to record also
  • gandrew
20 Fév 2021 22:37 #92616 par gandrew
Ok I understood my mistake.
I've to loop the speaker ouput to the microphone input and in MB Recaster I select Microphone for the acquisition card.
Is it right ?
20 Fév 2021 23:40 - 20 Fév 2021 23:40 #92617 par MB RADIO
it depends on what you want to stream with MB RECASTER. If you want to stream computer audio then turn the MB RECASTER monitor card to MBRecasterMix
and choose the loopback card as capture.
If, on the other hand, you have a mixer and you want to stream the mixer audio then you have to connect the mixer output to the computer input with a cable and then select that input in MB RECASTER.
Temps de génération de la page : 0.063 secondes
