Mb recasted help
  • Strawbs89
29 Juil 2019 19:58 - 29 Juil 2019 19:59 #88095 par Strawbs89
Mb recasted help a été créé par Strawbs89
Hi I’m new to mb recaster
Before I download it I have a few questions, Does it have a mic button
Do I have to port forward to run mb or is that optional????
29 Juil 2019 22:15 #88097 par MB RADIO
Réponse de MB RADIO sur le sujet Mb recasted help
MB RECASTER FREE do not have a Mic Button
MB RECASTER PRO has 3 inputs: Audio Card, Internet Stream, AutoDJ (local audio files). You can use Audio card as Mic Input if you want to talk over an internet stream or the local audio files.
You don't need to map the router unless you use the internal streaming server
  • Strawbs89
30 Juil 2019 02:05 #88098 par Strawbs89
Réponse de Strawbs89 sur le sujet Mb recasted help
Ok yes I want to talk over the stream can I do so in mb free
30 Juil 2019 12:59 #88101 par MB RADIO
I'm sorry there is no such feature in the free version.
