playlist ripetuta
25 Juil 2022 14:48 #95979 par Garganofm
playlist ripetuta a été créé par Garganofm
Buongiorno,  possibile che all'improvviso, una playlist contenente un jingle e un miniprogramma di due minuti,  vada in onda due volte di seguito,  senza alcun motivo?
ho provato a vedere se per caso ci fosse un mbspot con lo stesso contenuto, ma niente....
ore 07:40  e 07:42
07:40:32     Carica Playlist C:\MBStudio\Playlist\0740---lumamegivesa_Due minuti un libro.mbp
07:40:32     Tipologia: INTRATTENIMENTO -
07:40:32     1) File casuale: GARGANOFM - 00:00:00 -
07:40:32     Check > 2minuti.mp3
07:40:32     Opening audio ... C:\MBStudio\Download\2minuti.mp3 ... H:1066(-3)/U:2247/G:1555/Avm:480/Ml:60%
07:40:32     CreateFile: C:\MBStudio\Download\2minuti.mp3 = -2147463537 - 9 ms - H:1067(1)/U:2247/G:1555/Avm:480/Ml:60%
07:40:32     Controllo del silenzio ... Inizio ...
07:40:32     Controllo del silenzio ... Fine ...
07:40:32     Result: C:\MBStudio\Download\2minuti.mp3  - Start:0 - Intro:0 - RefIn:0 - RefOut:0 - Outro:0 - End:109,2316 - OrigLength:109,8068 - Fade out:Valori predefiniti - BassHandle:0 - 48 ms
07:40:32     2) 2minuti.mp3 - 00:01:49 -
07:40:32     File closed 1
07:40:32     \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
07:40:32     Random File at position 1 GARGANOFM
07:40:32     [[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[
07:40:32     File casuale - Ricerca del genere...GARGANOFM - at: 25.07.22 - 07.42.18 - Fascia: 7
07:40:32     Random File: ESTATE LINERS GARGANO FM 02.mp3 - GARGANOFM - Lastplay:25.07.22 05.46 - LastScheduledplay:
07:40:32     Check > ESTATE LINERS GARGANO FM 02.mp3
07:40:32     Opening audio ... C:\MBStudioonair\Random\ESTATE LINERS GARGANO FM 02.mp3 ... H:1065(-2)/U:2247/G:1555/Avm:480/Ml:60%
07:40:32     CreateFile: C:\MBStudioonair\Random\ESTATE LINERS GARGANO FM 02.mp3 = -2147463536 - 19 ms - H:1066(1)/U:2247/G:1555/Avm:480/Ml:60%
07:40:32     Result: C:\MBStudioonair\Random\ESTATE LINERS GARGANO FM 02.mp3  - Start:0 - Intro:0 - RefIn:0 - RefOut:0 - Outro:0 - End:11,71698 - OrigLength:11,71698 - Fade out:Valori predefiniti - BassHandle:0 - 34 ms
07:40:32     ]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]
07:40:32     File at position 1 - ESTATE LINERS GARGANO FM 02.mp3
07:40:32     Check > C:\MBStudioonair\Random\ESTATE LINERS GARGANO FM 02.mp3
07:40:32     Opening audio ... C:\MBStudioonair\Random\ESTATE LINERS GARGANO FM 02.mp3 ... H:1065(-1)/U:2247/G:1555/Avm:480/Ml:60%
07:40:32     CreateFile: C:\MBStudioonair\Random\ESTATE LINERS GARGANO FM 02.mp3 = -2147463535 - 7 ms - H:1069(4)/U:2247/G:1555/Avm:476/Ml:60%
07:40:32     Result: C:\MBStudioonair\Random\ESTATE LINERS GARGANO FM 02.mp3 MP3 320kb - Start:0 - Intro:0 - RefIn:0 - RefOut:0 - Outro:0 - End:11,50236 - OrigLength:11,71698 - Fade out:Valori predefiniti - BassHandle:-2147463535 - 69 ms
07:42:17     Mix out - Position:109,232 - Outro:109,2316 - End:109,2316 - OrigLength:109,8068 - Fade out:+1 sec. - Timer:2398234,81429543
07:42:17     Fade Out handle=-2147463545 - speed=1 - Timer=2398234,81509439
07:42:17     On air:4 - C:\MBStudioonair\Random\ - ESTATE LINERS GARGANO FM 02.mp3 - Start:0 - Intro:0 - Ritin:0 - Ritout:0 - Outro:0 - End:11,50236 - OrigLength:11,71698 - Duration:11,50236 - Fade out:+1 sec. - BassHandle:-2147463535
>     ESTATE LINERS GARGANO FM 02.mp3 - - ESTATE LINERS GARGANO FM 02
>      - C:\MBStudioonair\Random\ESTATE LINERS GARGANO FM 02.mp3 MP3 320kb - Flag2:16403
>     Playlist: 0740---lumamegivesa_Due minuti un libro.mbp - Title: Due minuti un libro - Comment: INTRATTENIMENTO - Actual: Due minuti un libro - Timer:2398234,83760629 -  BassHandles:10 - H:1072(3)/U:2245/G:1547/Avm:476/Ml:60%
07:42:20     File at position 1 - 2minuti.mp3
07:42:20     Check > C:\MBStudio\Download\2minuti.mp3
07:42:20     Opening audio ... C:\MBStudio\Download\2minuti.mp3 ... H:1068(-4)/U:2244/G:1546/Avm:480/Ml:60%
07:42:20     CreateFile: C:\MBStudio\Download\2minuti.mp3 = -2147463527 - 22 ms - H:1072(4)/U:2244/G:1546/Avm:476/Ml:60%
07:42:20     Controllo del silenzio ... Inizio ...
07:42:20     Controllo del silenzio ... Fine ...
07:42:20     Result: C:\MBStudio\Download\2minuti.mp3 MP3 256kb - Start:0 - Intro:0 - RefIn:0 - RefOut:0 - Outro:0 - End:109,2316 - OrigLength:109,8068 - Fade out:Valori predefiniti - BassHandle:-2147463527 - 67 ms
07:42:29     Mix out - Position:11,503 - Outro:11,50236 - End:11,50236 - OrigLength:11,71698 - Fade out:+1 sec. - Timer:2398246,16937529
07:42:29     Fade Out handle=-2147463535 - speed=1 - Timer=2398246,1699546
07:42:29     On air:4 - C:\MBStudio\Download\ - 2minuti.mp3 - Start:0 - Intro:0 - Ritin:0 - Ritout:0 - Outro:0 - End:109,2316 - OrigLength:109,8068 - Duration:109,2316 - Fade out:+1 sec. - BassHandle:-2147463527
>     2minuti.mp3
25 Juil 2022 15:21 - 25 Juil 2022 15:23 #95981 par MB RADIO
Réponse de MB RADIO sur le sujet playlist ripetuta
sembra che si tratti di una vecchia versione di MB STUDIO. Nelle vecchie versioni la durata di una playlist escluso l'ultimo oggetto deve essere superiore a 1 minuto altrimenti si ripete. Quindi se ad esempio la tua playlist è composta da soli 2 oggetti il primo deve durare oltre 1 minuto. Puoi risolvere programmando la rubrica in MB SPOT anziche' fare una playlist oppure aggiungi un jingle alla fine della playlist
Il problema non è presente nelle ultime versioni di MB STUDIO.
