Desktop Ticker
08 Sep 2023 21:44 - 08 Sep 2023 21:45 #98557 par Medeiros
Desktop Ticker a été créé par Medeiros
Is it possible to put the font in bold?
I have a problem, it doesn't detect the letter "â"
Regarding the weather, I also have a problem, I don't know what "Percebida" is (It doesn't exist in Portuguese).
08 Sep 2023 21:53 - 08 Sep 2023 21:54 #98558 par MB RADIO
Réponse de MB RADIO sur le sujet Desktop Ticker
no
try to use another font, maybe the current font do not have that letter a
"percebida" is the "feels like" temperature is a measurement of how hot or cold it really feels like outside. The “Feels Like” temperature relies on environmental data including the ambient air temperature, relative humidity, and wind speed to determine how weather conditions feel to bare skin.Different combinations of temperature, humidity, and wind speed can increase the sensation of being hot or cold. For example, skin that is exposed to wind and cold temperatures will make a person feel that it is colder outside than it really is because heat is drawn away from the body at a faster rate. As another example, a day that is very humid may feel hotter than it really is outside because your body sweat does not evaporate (and thereby cool the body) the way it is intended.
www.acurite.com/learn/glossary/feels-like-temperature
13 Sep 2023 17:42 - 13 Sep 2023 17:43 #98598 par Medeiros
Réponse de Medeiros sur le sujet Desktop Ticker
It seems to be a bug, only the "Â" does not appear, for example "Ê" appears.
You can test it there.
14 Sep 2023 15:16 #98605 par MB RADIO
what is the url of the feed?
14 Sep 2023 15:19 - 14 Sep 2023 15:27 #98606 par Medeiros
www.radiosines.pt/feed1
I am using the font: Arial, Size 20.
