ESI MAYA44 eX
08 Mai 2023 13:23 #97982 par MB RADIO
Réponse de MB RADIO sur le sujet ESI MAYA44 eX
this function already exists
example to prelisten input EXt2, set the output where you want and move up the slider EXT2
example to brodcast input EXT2, set the ouput to MB STUDIO MIX and move up the slider EXT or click TALK
08 Mai 2023 15:24 - 08 Mai 2023 15:27 #97985 par Medeiros
Réponse de Medeiros sur le sujet ESI MAYA44 eX
I understood.
But it's still not practical.
Because we have to do a pre-listening and when the time is right to go into broadcast.
With this option that indicates: Whoever is in the studio has to change the output of the audio card that is in pre-listening and put another one for emission and also the talk. This doesn't seem practical.
This is good to make a chain with another radio, when you know the exact moment to enter.
As for the option I suggest, whoever is in the studio does the pre-listening and broadcasts it through the pre-listening audio card when the time is right using the studio mixer.
08 Mai 2023 16:03 - 08 Mai 2023 16:04 #97987 par MB RADIO
you can also put the EXT in the instant playlist and prelisten or broadcast from there:
08 Mai 2023 16:17 #97988 par Medeiros
It's good this way.
It was hard. Thanks.
