Playlist question
  • davefrmn2019
15 Avr 2022 19:31 #95415 par davefrmn2019
Playlist question a été créé par davefrmn2019
I noticed when i add songs to the on air playlist they are not shuffled but it order by artist. Is there anyway to get them inot the on air playlist in s shuffled list ?
15 Avr 2022 19:39 - 15 Avr 2022 19:40 #95416 par MB RADIO
Réponse de MB RADIO sur le sujet Playlist question
When you add a random song to a playlist you can choose between some methods like "Least Recently Played" or "Random" etc etc
see here: www.mbradio.it/en/support/help/115-playl...ndom-song-parameters
in a fresh started automation all songs has been added pretty at the same time so if you use "Least Recently Played" you can see songs playing in alphabetical order. In a fresh started system it's better to use "Random" and "Least Times Played"
  • davefrmn2019
15 Avr 2022 21:25 #95419 par davefrmn2019
Réponse de davefrmn2019 sur le sujet Playlist question
Thanks but what i meant was when importing songs from add a file for around 300 songs they show up in the playlist in alphabetical order, is there a way to import in a random order or change to random order ?
15 Avr 2022 21:29 - 15 Avr 2022 21:36 #95420 par MB RADIO
no..the order is the same that you load from the disk ....but let me say that's not a good way to use an automation system ... if you load the songs directly inside the playlist it's like to use windws media player. The right way to use the power of an automation system is to use Random Song item in your playlist: www.mbradio.it/en/support/help/115-playl...ndom-song-parameters
  • davefrmn2019
15 Avr 2022 21:39 #95421 par davefrmn2019
I also wanted to know when using the instant recorder and the headset mic is shutoff between songs the recording record silence, is there was to set so it only recording the show when the swtch is on without leaving the mic switch on ?
15 Avr 2022 21:42 #95422 par MB RADIO
sorry i do not understand this question. open a new topic for this and add some pics to explain
  • davefrmn2019
15 Avr 2022 21:44 #95423 par davefrmn2019
oh ok thanks...
