MB Remote
09 Avr 2022 20:49 - 09 Avr 2022 20:50 #95364 par Medeiros
MB Remote a été créé par Medeiros
Is it normal in MB Remote (1.70.3.5) for the list to be in black?
I can't get the settings predefined by me on the MB Remote in the music columns. I always have to change.
09 Avr 2022 20:53 #95365 par MB RADIO
Réponse de MB RADIO sur le sujet MB Remote
the colors and settings are the same as the MB STUDIO you connect to.
09 Avr 2022 20:59 - 09 Avr 2022 21:00 #95366 par Medeiros
Réponse de Medeiros sur le sujet MB Remote
On mine the colors don't look like it.
The photo I send now is from MBstudio.
09 Avr 2022 21:32 #95367 par MB RADIO
Probably the MBstudio data fodler is not c:\MBStudio but something else so MB REMOTE use the settings of that folder
www.mbradio.it/en/support/help/113-confi...onfiguration-network
10 Avr 2022 03:11 - 10 Avr 2022 03:11 #95369 par Medeiros
mine is in Z:\
Because mine is like this because it is using the server.
10 Avr 2022 23:11 #95375 par MB RADIO
ok, for now MB REMOTE do not support that configuration, i will look to support it as soon as possible.
11 Avr 2022 00:45 #95376 par Medeiros
OK. I will be waiting.
Thanks.
