UDP commands
11 Nov 2021 00:47 #94179 par Medeiros
UDP commands a été créé par Medeiros
I installed version 8.69.2 and now the UDP commands from the Axel Oxygen 3000 mixer stopped working.
Everything was working fine until this version of Mbstudio was installed.
I urgently needed to know what to do as it is important for our visual radio.
11 Nov 2021 01:06 - 11 Nov 2021 01:13 #94180 par MB RADIO
Réponse de MB RADIO sur le sujet UDP commands
Absolutely nothing has been changed.
Try to send commands with UDPClient.exe. If it works you know that nothing is wrong on MB STUDIO side
11 Nov 2021 16:31 - 11 Nov 2021 16:34 #94198 par Medeiros
Réponse de Medeiros sur le sujet UDP commands
UDP Client is working.
And it just stopped working after the MBStudio update.
But the port is not the same as -1 because with this -1 port it doesn't work.
11 Nov 2021 16:33 #94199 par MB RADIO
If UDPCLient.exe is working then MB STUDIO is ok. You must check if the IP Port and password are correct in the mixer configuration.
11 Nov 2021 16:41 #94200 par Medeiros
Example: I have port 92.90 in mbstudio and I use port 92.89 in the software, ie port -1 is not working
11 Nov 2021 17:33 - 11 Nov 2021 17:33 #94203 par MB RADIO
Maybe the windows firewall has blocked the UDP from another source in the LAN?
Try to send commands with UDPClient.exe from another computer.
11 Nov 2021 17:45 #94206 par MB RADIO
Also check if the mixer is sending commands like explained here: www.mbradio.it/en/support/help/742-udp-api-2
11 Nov 2021 18:09 #94209 par Medeiros
Here it was:
12 Nov 2021 09:55 #94229 par MB RADIO
12 Nov 2021 14:10 #94238 par Medeiros
I already sent it.
12 Nov 2021 15:16 #94240 par MB RADIO
i replied
Temps de génération de la page : 0.068 secondes
