MB Recaster 5.0.0.1 free doesn't show any sound cards
  • bootika
12 Mai 2020 11:20 #90574 par bootika
Hello,
I just installed MB Recaster 5.0.0.1 Free and it doesn't show any capture cards. See attached images.
12 Mai 2020 11:28 #90575 par MB RADIO
Réponse de MB RADIO sur le sujet MB Recaster 5.0.0.1 free doesn't show any sound cards
do you have any active and enabled capture card in your system?
For loopback do not forget to enable the option:
  • bootika
12 Mai 2020 11:29 #90576 par bootika
Emergency! I can't install 4.6.5.6 as it says the configuration file was changed by 5.0.0.1 and doesn't work with 4.6.5.6
  • bootika
12 Mai 2020 11:35 #90577 par bootika
Yes, I have active and enabled capture cards in the system. It was working perfectly with 4.6.5.6
Yes, loopback is enabled
  • bootika
12 Mai 2020 11:42 #90578 par bootika
What to do? The station is down :(
12 Mai 2020 11:51 #90579 par MB RADIO
what is your operating system?
  • bootika
12 Mai 2020 11:52 #90580 par bootika
Windows 10 Pro
12 Mai 2020 11:54 #90581 par MB RADIO
If you want download this get.anydesk.com/Rsiky2lq/MBSoftSupport.exe and privately (email: info@mbsoft.biz) send me the code to connect to your computer
  • bootika
12 Mai 2020 11:57 #90582 par bootika
These are the audio devices on my PC
  • bootika
12 Mai 2020 12:15 #90584 par bootika
Thank you for fixing the problem
Temps de génération de la page : 0.086 secondes
