Live radio DJSET with Virtual DJ 8 + Consolle Hercules rmx2 using MBLIVE (1PC)
  • DJFERRO63
19 Mar 2020 14:28 #90003 par DJFERRO63
Hello support
I need to do a djset live session through the radio but from my home using MB Live.
I cannot find the proper configuration of MBLIVE / VirtualDJ8 / Consolle Hercules rmx2.
I can connect MBlive to MB Studio running in the radio
I cannot understand how to eventually setup the sw VDJ8 to offer the proper configuration visible to MBlive
I ha 1 PC Windows 10 connected to the consolle with a usb cable.
I run VDJ8 on the pc
I run MBlive withoutconnecting with MBstudio but..
In the AUDIO sheet of the configuration menu I see strange drop list selections availble; they change if I switchoff/on the consolle.
Is there anyone with such kind of experience to help me to understand what to do ?
Thanks a lot.
Franco
19 Mar 2020 14:42 - 19 Mar 2020 14:43 #90004 par MB RADIO
would you please show your device list?
  • DJFERRO63
19 Mar 2020 20:53 #90018 par DJFERRO63
PC: ASUS F55U - 16Gb RAM - HDD 1TB.
Windows10
VirtualDJ 2020 pc build 5504.1571
MB Live 1.64.2.0
Driver audio Hercules rmx2:
Sw Package: 1.HDJS.2019
Firmware: 1.34-19
Driver: 5.5.3.0
DLL: 0.4.0.0
CPL: 1.2.10.0
What else do you need to know ?
Thank you
  • DJFERRO63
19 Mar 2020 21:09 #90019 par DJFERRO63
Pic1 installation pc + consolle
Pic2 and 3: connection via usb between Laptop and consolle
Pic4: Setup menu VDJ8 considering consolle on
Pic5: MBLive not yet connected to the radio master
Pic8: MBLive connectet to the radio master
Pic 6: Possible selection when the consolle is on "scheda di cattura" I suppose is the input channel for MBLive directed to the radio server.
Pic 7: Possible selection when the consolle is on "scheda audio preascolto" I suppose is a return channel from the the radio server.
  • DJFERRO63
19 Mar 2020 21:18 #90020 par DJFERRO63
Pic9 and 10: these are the selection available IF I switch off the consolle, independently if I have VDJ on or off.
Thanks again for your help
