Mbstudio restart!
07 Fév 2020 00:17 #89564 par Medeiros
Mbstudio restart! a été créé par Medeiros
Hi
I notice that sometimes MB Studio shuts down and reconnects without having scheduled a software restart.
Is this normal now?
07 Fév 2020 00:27 #89565 par MB RADIO
Réponse de MB RADIO sur le sujet Mbstudio restart!
It's possible this happens if the system resources goes down, the software restart to avoid a crash.
07 Fév 2020 00:33 - 07 Fév 2020 00:35 #89566 par Medeiros
Réponse de Medeiros sur le sujet Mbstudio restart!
This is happening about 2 to 3 days.
If it does not cut the audio, it always leaves the audio at the end.
Is there another solution?
07 Fév 2020 00:38 #89567 par MB RADIO
Without restart the program will crash. It should be searched what is causing the low resources. Are you using OBS in the same computer? or VMix?
07 Fév 2020 00:41 #89568 par Medeiros
I'm using the same computer OBS.
07 Fév 2020 00:50 #89569 par MB RADIO
ok, if you want send a debug and i will look into it.
07 Fév 2020 00:52 #89570 par Medeiros
Tomorrow I send.
Thanks.
