weather zero degrees
  • paul03034
25 Jan 2020 17:13 #89414 par paul03034
weather zero degrees a été créé par paul03034
Hello,
Is there any way to prevent when MBStudio is updated that the weather does not announce zero degrees for the low temp?
It might happen with reboot also, not sure, but it sounds very bad when you do weather and it says high of 35 degrees and then the low zero degrees when it was really 33 degrees.
Thank you!
26 Jan 2020 17:16 #89423 par MB RADIO
Réponse de MB RADIO sur le sujet weather zero degrees
You don't have to announce the lowest temperature of the day before 1am
Les utilisateur(s) suivant ont remercié: paul03034
