FTP audio file to folder in MBStudio
  • paul03034
07 Aoû 2019 04:09 #88160 par paul03034
FTP audio file to folder in MBStudio a été créé par paul03034
Hello,
I think the answer is probably no, but I will ask.
I tried Radio Spider, but it appears some program uses older C+++2010 runtime files as I cannot install, but on same OS different computer it is okay. so that route is dead.
Can I FTP from site a file that has a date format for the day.
They add a new audio file each new day in their site Year-Month-Day.mp3
I rename the file that comes out with Mondays date Monday CAMonday.mp3 and schedule to play on that day in MBspot.
The folder that holds the audio is CAWeekly and in there are 5 audio files CAMonday.mp3, CATuesday.mp3, etc.
Can this be done automatically in MBStudio?
Thanks,
Paul
07 Aoû 2019 11:38 #88161 par MB RADIO
Réponse de MB RADIO sur le sujet FTP audio file to folder in MBStudio
  • paul03034
08 Aoû 2019 00:36 #88164 par paul03034
Réponse de paul03034 sur le sujet FTP audio file to folder in MBStudio
Okay I see and very good on that!
I do not find FTP import function in help, so does that exist?
Only thing is on FTP you need to specify the file for the day to get year-month-day as their directory has hundreds of files and each day they add new file for that day.
Thank you!
Paul
08 Aoû 2019 02:25 - 08 Aoû 2019 02:27 #88165 par MB RADIO
in the following exemple i download a file with the current date and i save it without date as news.mp3 so i can easy schedule it in playlist or breaks.
Les utilisateur(s) suivant ont remercié: paul03034
  • paul03034
09 Aoû 2019 02:23 #88166 par paul03034
I am stupid, I did not see download function. I never notice, I must be blind!
Excellent functions to do what I need!
Thank you!
