Refresh Breaks causing long silence
  • paul03034
28 Jui 2019 02:57 #87954 par paul03034
Refresh Breaks causing long silence a été créé par paul03034
Hello,
I have noticed that if refresh breaks happens during a audio file transition, everything stops and it sits silent/frozen for up to say 15 seconds, refresh break closes and new audio file plays, so it sounds very bad as I was driving several times while listening to radio station (several hours driving) and all of a sudden audio paused and came back and I didn't know why, but I have seen it several times now while watching play-out it sets with reading sequences.dat.
Seems its too many things going on at once switch audio files and read break database.
HELP!
Thank you,
Paul
28 Jui 2019 14:54 - 28 Jui 2019 14:55 #87955 par MB RADIO
Réponse de MB RADIO sur le sujet Refresh Breaks causing long silence
You should send a report via menu help / send debug MB SOFT. i'm unable to investigate via forum.
I also suggest you to disable the auto refresh
