Velleman Card
  • teutoradio
26 Jan 2019 21:00 #87008 par teutoradio
Velleman Card a été créé par teutoradio
Hello,
can I use also the output from the vellman card or only the inputs?
26 Jan 2019 23:03 #87010 par MB RADIO
Réponse de MB RADIO sur le sujet Velleman Card
Yes you can
  • teutoradio
26 Jan 2019 23:21 #87011 par teutoradio
Réponse de teutoradio sur le sujet Velleman Card
We need tor program in the folloowing way: when a special mp3 file starts everytime, at the begin of the mp3, the vellman card should send a signal output and when the mp3 ends, agian ouput signal to our mixer console. How to proogram? I only find 5 bits input, but we need to get an output signal
27 Jan 2019 00:40 #87012 par MB RADIO
In the properties of any item you can enable or disable the BIT 1 to 8 as you like:
  • teutoradio
27 Jan 2019 00:58 #87013 par teutoradio
Ok thanks, it works but only with a short bit signal, we need bit 1 the complete mp3 file on and at the end bit1 off
Possible??
27 Jan 2019 01:12 #87014 par MB RADIO
