MB LIVE per Android
21 Jan 2019 16:58 - 22 Jan 2019 01:53 #86936 par Medeiros
Lavori in corso: MB LIVE Android a été créé par Medeiros
Will it be possible in the settings to have the option to enable/disable: "Keep the screen turned on"
This is so that your smartphone/tablet does not turn off the screen.
21 Jan 2019 17:00 #86937 par MB RADIO
Réponse de MB RADIO sur le sujet MB LIVE per Android
I don't know. I have to investigate and i don't know if the Android OS give me the permisison to do so.
21 Jan 2019 17:21 #86938 par MB RADIO
Réponse de MB RADIO sur le sujet MB LIVE ANDROID is available for download
22 Jan 2019 01:15 #86947 par Medeiros
Réponse de Medeiros sur le sujet MB LIVE per Android
Luci Android software has this option.
I think it's possible.
22 Jan 2019 01:53 #86948 par MB RADIO
I will add it in few days
22 Jan 2019 02:31 - 22 Jan 2019 02:32 #86949 par Medeiros
Thanks. :)
24 Jan 2019 11:40 #86963 par MB RADIO
25 Jan 2019 13:45 - 25 Jan 2019 13:51 #86979 par Medeiros
MB SOFT écrit: added on version 1.62.0.5 play.google.com/store/apps/details?id=mbsoft.mblive&hl=en
Thank you Maurizio.
I do not want to bother.
Will it be possible to create multiple configuration profiles for MB LIVE on Windows and Android?
This is so that you may have to use two or more different ips / ports / passwords and not have to always load configuration data.
25 Jan 2019 13:49 #86980 par MB RADIO
On windows you can already do it.
On androud i will add it
25 Jan 2019 13:56 #86981 par Medeiros
MB SOFT écrit: On windows you can already do it.
Ok...thanks.
