External Stream
  • teutoradio
08 Oct 2018 15:21 #86259 par teutoradio
External Stream a été créé par teutoradio
Dear Maurizio,
can I use the external Stream in MB Radio for commands like "play commercial, "back to the Stream" if in the stream id will played a special text file like play commercial?
I mean, every time when this "title" will be played in the external stream, MB Radio will do a special command?
08 Oct 2018 15:47 #86262 par MB RADIO
Réponse de MB RADIO sur le sujet External Stream
No, the only thing you can do is to finish the external stream when the "word" is received on the metadata. So, for exemple, if the remote station write "commercials" during the break you can have MB STUDIO disconnect from the external stream and eventually play your own breaks.
