Problem with Random Files
  • teutoradio
25 Sep 2018 10:59 #86096 par teutoradio
Problem with Random Files a été créé par teutoradio
I have the following problem:
I create at the same time 10 different files as "Random Files" with the same genre.
In my playlist i want to play every hour one file of this randomly.
So the best would be, if MB Radio plays first only files that was not on air before. In my example the next 10 hours it should be always a different file.
But MB radio plays every hour the same file and no file that was not on air before.
Is this maybe a problem in the version 8.61.3.0 ??
25 Sep 2018 11:36 #86097 par MB RADIO
Réponse de MB RADIO sur le sujet Problem with Random Files
For sure there is a problem, would you please send the debug to get your problem investigated?
  • teutoradio
25 Sep 2018 11:42 #86098 par teutoradio
Réponse de teutoradio sur le sujet Problem with Random Files
OK, I send you the debug
25 Sep 2018 12:35 #86099 par MB RADIO
it's now fixed in version 8.61.3.2
  • teutoradio
25 Sep 2018 12:36 #86100 par teutoradio
Thanks
