Playlist
  • teutoradio
21 Sep 2018 08:44 #86058 par teutoradio
Playlist a été créé par teutoradio
How can I solve the problem?
I create playlist per hour and disable at begin the break option. Into the playlist I build he breaks. My problem: at :30 i have planned a break with a force of 1 minute, so the break will start at :31 latest, but only if i do not plan the breaks into the playlist and enable the breaks.
If i build in the break :30 directly into the playlist the "force" option will not work, and the :30 break can start for example at :033, depends on the length of the songs before. Any solution how to solve it?
21 Sep 2018 13:12 - 21 Sep 2018 13:15 #86059 par MB RADIO
Réponse de MB RADIO sur le sujet Playlist
The "force" option only work when breaks are automatcially inserted by MB STUDIO. Do not work when you insert that break into a playlist. You can use a workaround. Do not put that break into playlist, go to agenda and set an internal command "Enable breaks" at let's say 13:30 and a disable break at let's say 13:32
